Dashboard lights.
Old Nov 9, 2015 | 08:36 AM
Al Whitelock's Avatar
Default Dashboard lights.
I've had great help here on the forums before so let's see if anyone's had this issue before.
Ok I start car, all gauges work good. Switch on thE headlights and all the gauges go to the top/max , speedo and tach quit , dash lights don't come on.
Switch lights off ...all gauges work good again.
Repeat til it gets boring.
Any suggestions ? , I've never been into the dash of this car before .
Old Nov 9, 2015 | 10:37 AM
Doug's Avatar
Almost certainly a poor ground/earth at the instrument cluster.
Poor/corroded connections at the back of the instrument cluster are common. Remove cluster (fairly easy task) and carefully clean all contact points and connectors...AND add a redundant ground wire
Old Nov 9, 2015 | 06:07 PM
Bc xj's Avatar
I agree with Doug. Probably a bad ground or connection on dash
Old Nov 9, 2015 | 07:15 PM
kenatofc's Avatar
Only a few screws to take off and some connections in the back of the instrument cluster. Pull the steering wheel off... You will need a 13/15" socket... just put the wheel in the center position. When you take the cluster off, there will be a metal piece on the back of the panel. Clean it off, rough it up a little and reinstall.
ken in wv
Nightsounds
Nov 17, 2015 11:43 PM
brgjag
Nov 1, 2015 10:18 PM
jagger
Oct 26, 2015 06:48 PM
garyp
Oct 23, 2015 06:13 AM
DaveInVA
Oct 21, 2015 03:33 PM
