Defective Fuel Regulator
Old Oct 24, 2020 | 05:25 PM
jal1234's Avatar
If the seal diameters and depths are the same, it should. For the price, I'd sure try it
Old Jun 14, 2023 | 02:35 AM
yoopas's Avatar
Good afternoon, sorry to renew such an old post, but maybe someone found a solution for this regulator replacement?
My Hot fuel start system is not working correctly, starting only after second long crank (When hot first crank just cranks but not starts).
I assume its this pressure regulator and it seems to be not available everywhere.
1994 Facelift V12 6.0 XJS
Old Jun 14, 2023 | 03:38 AM
Pscottorn's Avatar
I ended up using a racing variable fuel pressure regulator pointed to the wing of the car. All has been fine since.
Old Jun 14, 2023 | 09:56 PM
purrkittypurr's Avatar
I've found an OEM regulator on ebay Germany a couple years ago. Although the Aeromotive one Greg in France linked in in his post could almost be mounted in place of the original one.
Old Sep 7, 2025 | 10:36 AM
kansanbrit's Avatar
What was your solution? I have the same problem.
Old Oct 6, 2025 | 10:50 AM
xjsv12's Avatar
https://www.ebay.com/itm/161578947603
Old Oct 7, 2025 | 07:41 AM
kansanbrit's Avatar
Originally Posted by xjsv12
Have you tried it ? Because many look the same but the diameters are different and they don't fit.
Old Oct 30, 2025 | 06:03 AM
  #28
xjsv12's Avatar
No I haven't tried it but it looks the same.
Old Oct 30, 2025 | 06:15 AM
xjsv12's Avatar
Daniel98
May 28, 2020 12:22 PM
worzella
May 26, 2020 07:17 AM
Mike Badyna
Nov 12, 2018 10:32 AM
katar83
Feb 6, 2018 07:49 PM
J_C_R
Feb 25, 2013 10:11 PM
