Xjs door hinge replacement
Old Oct 26, 2025 | 03:18 PM
Rchuda's Avatar
Default Xjs door hinge replacement
Need to source a manufactured Left side upper door hinge for 1994 XJS convertible. Is this a DYI job? Does the front fender have to be removed? I could not find a video on line.
Old Oct 26, 2025 | 03:32 PM
ptjs1's Avatar
Not sure where you'll source a hinge but, as you'll see from the Jaguar Parts website, note that there is apparently a changepoint at VIN 194774 which is April 1994, so just be aware.
Good luck
Paul
Old Oct 26, 2025 | 03:56 PM
Rchuda's Avatar
Default XJS hinge reply
I was not aware of that change. Thanks for heads up.
Old Oct 26, 2025 | 04:26 PM
ptjs1's Avatar
Have a look on the Jaguar Parts website for the relevant part numbers.
Paul
Old Oct 26, 2025 | 06:47 PM
RGK20m3's Avatar
I am assuming no significant change between my ‘88 and your ‘94….I removed both doors for refinishing.
The door side fasteners are 3 studs with nuts on each hinge accessed by removing the door trim panel, mark the nut locations on the inside to aid with initial alignment, also any shims. The body side lower is accessed by removing the cowl side trim, as are the electrical disconnects. The upper requires removal of the dash lower scuttle to access bolts.
I believe the easiest would be remove the door assembly by removing the door side nuts and unplugging the wiring. Then plenty of room to remove the hinge. No need to remove the fender.
Old Oct 27, 2025 | 12:01 PM
equiprx's Avatar
I can tell you for sure 1985 thru 1994 hinges did not change one bit.
Does NOT require removing the front fender.
Unless you broke the spring wire, why are you looking for one?
It's an extreme PITA to replace a hinge, and requires removing the door cards, and the interior kick panel.
None of the A post door fasteners are visible, so undoing them is a full day job.
Old Nov 2, 2025 | 03:55 AM
Asdrewq's Avatar
I've done this swap albeit on the right hand door for RHD. No need to remove fender & not particularly difficult. You just have to take the trim out on the inside to access.
Old Nov 2, 2025 | 11:06 AM
equiprx's Avatar
It's been a very long time since I did my door on my 94, but...
The things I recall are the nut inside the A post were particularly hard to find and undo.
Another thing that was nasty was re-inserting the rubber harness boot.
You should also have a door holder dolly, the door is extremely heavy.
Old Nov 2, 2025 | 11:22 AM
stephenniz's Avatar
Direct message me. I can supply you with a hinge. Give me your shipping zip code.
Stephen
mghirsch
Nov 9, 2024 05:42 PM
Terry007
Sep 5, 2023 01:13 PM
Gasgasbones
Apr 8, 2023 11:35 AM
Mmaaxx
May 10, 2021 08:44 AM
Rchuda
Nov 16, 2020 10:45 AM
