Do '95 XJS's need a code for the radio?
Old Nov 10, 2025 | 07:06 PM
davchr's Avatar
Default Do '95 XJS's need a code for the radio?
My '95's radio works now. I don't have a code for it and I am concerned if/when I need to disconnect the battery I will have a problem getting the radio to work again. I have been told that the '95's with removable faceplate do not have a code as the removable faceplate is the security. I checked with two dealers and they both said they don't have access for information on cars older than 2009. If someone has a '95 and a code then I probably need one. If someone has a '95, no code, has disconnected the battery, and not needed a code to get the radio working again that would be great information.
thanks,
Dave Christensen
Old Nov 11, 2025 | 02:16 AM
ptjs1's Avatar
David, I have a 94-built car with the face-off unit and there is no security code required after the battery is disconnected
Paul
Old Nov 25, 2025 | 06:28 PM
rickr's Avatar
My 96 also did not require a code. But a friend of mine's 92 did.
philwarner
Sep 8, 2024 02:05 PM
ericthexjs
Aug 3, 2023 08:35 PM
Markmbaha1
Sep 8, 2021 08:39 AM
TropicCat
Jul 13, 2021 10:51 AM
SeanPeterLynch
Jul 8, 2014 06:07 PM
