Does the Engine need to be running for the Brake Light to go out? (XJS V12)
Old Jul 20, 2015 | 05:26 PM
orangeblossom's Avatar
Default Does the Engine need to be running for the Brake Light to go out? (XJS V12)
Having been doing a rebuild of the Teves Braking System on my V12 XJS
I have also had to bleed the Brakes.
But does the Engine need to be running, before the Brake Light goes out, or should it go out with just the Ignition turned on.
There are a number of reasons why I don't want to start the Engine at the moment.
But the dashboard light in question, is the small round red one that looks like it has a brake shoe on each side.
Old Jul 20, 2015 | 07:24 PM
RagJag's Avatar
OB, I think the light should go out after a few seconds as long as the switch on the parking lever is closed by the lever being all the way down. Some others may chime in that have the same car.
RagJag
Old Jul 21, 2015 | 12:47 AM
RagJag
Thanks RJ but I think your Car 'may' have a slightly different ie more modern brake actuator, than mine has.
Old Jul 21, 2015 | 08:57 AM
RagJag's Avatar
Quite possible, OB. My lever has to be pulled up to tighten the cables to the brakes and the button on the end held down until the lever is lowered all the way down.
Luck.
Old Jul 21, 2015 | 09:40 AM
ptjs1's Avatar
OB,
I think that Ragjag is talking about the handbrake light not the light that you're referring to. The Red brake warning (not handbrake) light coming on is part of the systems test procedure. It needs the pump running to ensure the accumulator is built up to pressure. It can take 30 secs + to do this. To answer your question, you don't need the engine running for this to happen. If it builds up sufficient pressure, the light will go out without the engine starting.
Hope that helps.
Paul
Old Jul 21, 2015 | 10:01 AM
Originally Posted by ptjs1
OB,
Hope that helps.
Paul
Thanks Paul
Another mystery solved but I didn't want to let the Pump run for a long time, in case it burnt out.
Old Jul 22, 2015 | 08:40 AM
RagJag's Avatar
OB, I did mistake the two brake lights.Sorry.
RahJag
BrentGardner
29
Dec 16, 2024 12:13 AM
1100me
Aug 27, 2020 11:37 PM
cheaperts
Aug 30, 2015 06:48 PM
rmbtl2
Aug 26, 2015 08:52 AM
