Door lock fuse amp rating?
Old Mar 19, 2016 | 04:17 PM
bullittandy's Avatar
Default Door lock fuse amp rating?
The fuse panel cover says 2 amp, the official manual I have says 3 amp, and a PDF copy of a 1989 XJS electrical diagram has it listed as a 7.5 amp.
I discovered this trouble shooting my locks. I replaced the solenoids and added an aftermarket remote locking kit. They worked for a while with the 5 amp fuse that was in the stock location but are now blowing a 5 amp fuse. But they are NOT blowing the 7.5 amp fuse I used after searching the PDF electrical diagram.
What say the experts?
Old Mar 19, 2016 | 04:21 PM
And to expand my inquiry: The aftermarket remote lock system I used has its own fuse, a 10 amp one. Could it be that the aftermarket remote lock system is overwhelming the stock fuse?
If that is the case, would it hurt to keep the 7.5 amp fuse in there?
Old Mar 22, 2016 | 02:39 AM
warrjon's Avatar
No it will not hurt to keep the 7.5amp fuse. The fuse is there to protect the wiring and other components from a failure. A total short will blow any fuse (within reason).
Old Mar 22, 2016 | 04:58 AM
I appreciate that expert opinion. After looking at the wiring for the door locks it is normal sized (don't know exact gauge) as compared to the rest of the wiring and is certainly capable of handling more than 3 amps. I've been using the 7.5 amp fuse for several days now and it is holding. I think the combination of the keyless entry and new solenoids mixed with ancient English curses overwhelmed the 5 amp fuse and the sweet spot is 7.5 amps.
And I agree, a total short will blow any fuse.
Old Mar 23, 2016 | 03:44 AM
warrjon's Avatar
Ah new aftermarket solenoids this now makes sense, (sorry I missed the replaced solenoids in your first post) if the solenoid coil is lower in resistance than the original Jag units they will draw more current, hence the blowing fuses. Most general wiring in cars is rated at 10A
Old Mar 26, 2016 | 06:13 PM
Paul_59's Avatar
Banned
My repair operation manual for 1990 model year onwards lists 10A as fuse rating for central door locking
Grant Eisworth
Nov 10, 2023 04:13 AM
Old Dude
Jul 19, 2016 09:57 PM
jagtoes
Mar 5, 2016 07:24 PM
redxk8
Mar 4, 2016 08:32 AM
brantman
Feb 25, 2016 06:17 PM
