door rubber replacement - HELP
Old Mar 4, 2016 | 11:48 AM
Tonyj's Avatar
Default door rubber replacement - HELP
Attempting to replace semi-facelift door rubbers Wish I had not started! It was so easy to pull the old rubber off
Is there a good, best place to start from? Is there a technique that makes it a little easier?
Getting somewhere with the bottom bit, with effort, but how do you get it in when you get to the hinges? Worried that having done the lower edge I'll get to a corner and it's too short or long. Also looking at the window bit
Has anyone got any hints please?
Thanks, Tony
Old Mar 4, 2016 | 12:07 PM
Doug's Avatar
Been there.
One or two or the corners are very well defined in the molding of the weatherstrip so I picked one and started from there. Then just started tucking the strip into the channel using a flat plastic tool. *Every few inches* I'd stop to see if the 'leg' I was working on would fall short, or run long, of the next intended stopping point and then slightly stretch or compress the weatherstrip to compensate. Some spray silicone helps.
The above makes it sound easy. It isn't. Itsa bitch !
The area along the hinges was tricky but somehow I managed. It was years and years ago....wish I could remember more, sorry
Old Mar 4, 2016 | 12:29 PM
Tonyj's Avatar
Thanks, I wonder how they managed at the factory? They must have had an easier way, surely! Thanks, Tony
Old Mar 5, 2016 | 02:44 AM
Lawrence's Avatar
Use liquid soap and a blunt screwdriver, ease it in a bit at a time.
ddsand
Jan 15, 2017 08:29 AM
adenshillito
Mar 28, 2016 10:13 AM
michaelodonnell123
Feb 25, 2016 01:14 PM
hawaiianjag
Feb 22, 2016 05:49 PM
Johnken
Feb 19, 2016 01:19 PM
