Doors
Old Apr 18, 2017 | 03:58 PM
brinny's Avatar
Default Doors
My 89 convertible doors are in poor shape. Does anyone know if I could use coupe doors and simply remove the window frames and swap over any necessarys. I have had a measure and the door body shells appear the same? Many thanks in advance for any help lads
Old Apr 18, 2017 | 06:40 PM
warrjon's Avatar
I know the 89 coupe doors have the window frames welded to the door whereas the convertible has frameless windows.
If it's rust in the bottom of the doors it would be easier to cut it out and weld new metal in.
Old Apr 23, 2017 | 04:18 AM
Paul_59's Avatar
Banned
I don't know if facelift doors are the same size, but I do know that my 93 6.0 facelift coupe has frameless door window
Old Apr 23, 2017 | 04:53 AM
Daim's Avatar
The door size is the same. The skins are different, due to different handles.
Old Apr 23, 2017 | 08:43 AM
Some Day, Some Day's Avatar
Coupe doors from the early facelifts should work, as they have the old-style lift-up handles that my wife hates.
Old Apr 23, 2017 | 11:47 AM
Daim's Avatar
No they won't as all prefacelifts had the little quarter light and the window had a frame. Again, welded.
Old Apr 23, 2017 | 05:18 PM
But would you need those quarter lights? If the shape's the same, just get some vehicle-side sealing strips for the A pillar and replace the whole thing.
Unless it's never that simple....
Old Apr 23, 2017 | 10:47 PM
Daim's Avatar
It's never that simple as the hinges changed as well
Old Apr 23, 2017 | 10:58 PM
Naturally.... ツ
Where are all the emoji in this horrible new format?
