Driver's window help
Old Sep 28, 2013 | 11:43 AM
msh1995xjs's Avatar
Default Driver's window help
My driver's side power window is stuck open. I have scoured the manual and online schematics and can not find a fuse/relay location to begin trouble shooting. Any assistance would be appreciated.
Old Sep 28, 2013 | 11:53 AM
jimbov8's Avatar
It appears they are both from the same fuse. F17 30A left hand fuse panel.
If the passenger side works you may have to look at the mechanism inside the door.
Hope this helps,
Old Sep 28, 2013 | 01:31 PM
Valander's Avatar
Hope this helps,
Yup, both windows are on the same fuse. If your passenger side window switch works, before tearing into the driver side door, I'd say open up the center console and temporarily switch the plugs (just pull the wire harness from them and stick it on the other switch), and see if that works. If so, then it's just the switch, which you can either take apart and clean, or just get new switches. I got a pair of switches for my 86 off of Amazon for less than 8 bucks a piece, now both windows work perfectly.
99xk8guy
Sep 29, 2025 10:51 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
sadepol01
Sep 11, 2015 05:26 AM
