ecu key
Old Apr 19, 2018 | 09:40 AM
rgp's Avatar
rgp
Default ecu key
anyone know of a supplier of the mixture adjustment key/knob that fits in the ecu,... now I've adjusted the followers It needs to be sorted a bit
Old Apr 19, 2018 | 09:55 AM
Greg in France's Avatar
Rex
This is what I did, I found a bit of Bundy tube: O/D just less than the hole, and carefully flattened it one one side to grip the "D"-shaped inner spindle. Worked a treat.
https://www.airsupplies.co.uk/bundy-tube-imperial
The Bundy tube was the only thing I could find rigid enough by thin enough to fit between the hole and the spindle.
Greg
Old Apr 19, 2018 | 02:04 PM
Jagboi64's Avatar
I used a piece of stainless tubing just like Greg suggested. It doesn't take much to turn the adjuster.
If you have a later car with the airbags, a piece of tubing also makes a great airbag disarming tool to allow steering wheel removal.
Old Apr 19, 2018 | 02:23 PM
JigJag's Avatar
Or pop the ECU open, unmount the pot from its bracket, remove the bracket and mount the pot in the access hole. Done.
Old Apr 19, 2018 | 04:08 PM
smgdata's Avatar
I used a plastic ball point pen housing, it just slipped right over the knob and it was easy to turn I could feel the clicks as well.
Old Apr 27, 2018 | 12:44 AM
user 652867429824's Avatar
I used the metal tubing from a small paint brush. did have to crimp it, then added a bit of solder to the seem after the fitting. I also wound some tape on for the handle/finger end. will try to remember to take a pic to show you. I saw one once on Ebay, I think they were asking about 35 dollars
Old Apr 27, 2018 | 12:50 AM
Here you go, I made mine in a similar fashion
Sean's Jaguar Tech Pages - Jaguar EFI ECU Adjustment Tool
Old Apr 27, 2018 | 09:36 PM
VancouverXJ6's Avatar
Is there a writeup on how to reset to baseline and what each click does in either direction?
Old Aug 23, 2022 | 01:49 PM
rgp's Avatar
rgp
How do you mean, any pics pls
sales@ECU Tuning Group
May 27, 2020 10:50 AM
May 6, 2020 11:26 AM
Apr 27, 2018 07:22 AM
Apr 14, 2018 11:31 PM
37
May 29, 2016 06:27 AM
