efi harness wiring diagram anyone?
so i have one side of my harness done and from what i can see there are only 4 separate injector sequences, 2 per side and alternating the injectors from front to back. like on one side i have yellow stripe and blue stripe alternating but on the original harness the wires are so cracked and twisted around i cant quite confirm ive done it right. any one have a wiring diagram and injector hook up sequence i can reference from?
Click here
http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Scroll down thru the Ser III XJ6 section and you'll see the pre-1988 XJS section. Then go to page 24.1
As Doug said.
The firing bunching of the injectors is:
1A/3A/5A
2A/4A/6A
1B/3B/5B
2B/4B/6B
It is not sequencial.
The ECU, via the resistor pack simply fires the injectors.
I run a 12v IGN common to all 12 injectors, then group off each 3 as per above with the earth trigger.
I have a diagram somewhere in this laptop of that. When I get back home I will find it and repost with it attached.
1A/3A/5A
2A/4A/6A
1B/3B/5B
2B/4B/6B
Daniel Howden
Sep 13, 2015 02:28 PM
