Engine and tranny or engine then tranny?
Old Jun 26, 2018 | 04:23 AM
Daim's Avatar
Default Engine and tranny or engine then tranny?
Hey guys,
I was wondering what the best way would be to reinsert the engine and tranny back into my old Gal...
Is it cleverest to fit them as one unit (i.e. engine and transmission slipped in from the top) or would it make more sense to fit the engine and then the tranny from underneath? This may sound a little weird, but I am wanting to fit it all without damaging the engine bay after repairs are done and also keep the engine tidy (avoiding getting it hit somewhere etc.). I think it may be easier and less likely to cause any damage if the engine was fitted first... It could glide onto the engine mounts and then carefully lean back to accept the transmission. I know the tranny can be removed and refit without removing the engine, as it states so in the repairs book, but what would really be cleverest?
Damien
Old Jun 26, 2018 | 05:29 AM
bladerunner919's Avatar
Depends on what facilities you have. Unless you have a lift to raise the car and can work at head-height, personally I'd be putting them in as a single unit. Fitting the gearbox on its own, with the car just jacked up will be a real pain.
Old Jun 26, 2018 | 05:46 AM
One unit, straight in, all done.
Old Jun 26, 2018 | 07:00 AM
baxtor's Avatar
All in as a single unit. It will simplify things if you use a tilt adapter and a small trolley jack beneath car to pick up rear of gearbox as it all moves down and back.
Old Jun 26, 2018 | 07:12 AM
Daim's Avatar
Hmm okay. I had issues getting it out in one piece which is why I asked...
Old Jun 26, 2018 | 07:43 AM
What problems did you have? I assume you were using an engine hoist and load leveller?
Old Jun 26, 2018 | 08:36 AM
Daim's Avatar
As the engine cranes you can get here are basically not long enough to get into the engine bay nor are te feel narrow enough to get under the engine between the front wheels, I was force to use a crank (not fully loadable) as well as a pulley on some scaffolding. All rollable. The pulley would hold the weight. The crank adjust the angle.
Old Jun 26, 2018 | 09:01 AM
Put the car on stands and take the wheels off to get them out of the way. I can't imagine an engine crane in Germany is any different/shorter to the rest of the world?
Old Jun 26, 2018 | 09:10 AM
Daim's Avatar
Did that, didn't work well... Worked with the scaffold setup. But I'd like to do it with less riskieren of destrying either the engine bay or te engine. After all that time and money was invested...
Old Jun 26, 2018 | 09:41 AM
Strange. Can you post a picture of the engine crane - I'm curious to see whether there's something odd about it.
Old Jun 26, 2018 | 10:29 AM
Daim's Avatar
I rented it 2016... Can't find a picture. Most have a capacity of like 500 kg with the arm fully extended...
Old Jun 26, 2018 | 10:42 AM
Sounds like the one I have. I don't really understand why it won't work. Did you do anything different to this chap?
Old Jun 26, 2018 | 10:57 AM
Daim's Avatar
As said, the legs were a lot wider...
Old Jun 27, 2018 | 10:09 PM
89 Jacobra's Avatar
Active Streak: 30 Days
I had a definite "issue" using a crane / cherrypicker, as we say in the USA. The legs of the cherrypicker hit the lower control arms, and it was a real pain getting all the way into the engine, with the front bumper on, as I had to extend the arm on the crane. Then the weight with the arm extended, was such that it wanted to lift the back of the crane. So it took 2 people to pull it out. But we got it done. In hind sight I would have put the car on stands to lift the front a couple inches and pull the tires. Or put a couple pieces of 2"x 8" Board under each front tire which would have let the cherry picker legs clear the lower control arms, and it wouldn't have raised it so much as to complicate the angle needed to slide the engine and trans into the chassis. Just a few thoughts. From experience.
Jack
Old Jun 28, 2018 | 03:18 AM
brinny's Avatar
I lifted mine out using a set of chain blocks. Slung it with a bit of tilt and as I lifted the engine I moved the car back as required.needs must but no issues.
Old Jun 28, 2018 | 04:21 AM
Daim's Avatar
I basically got it out the same way, just that my chain pulley was moveable...
Problem is getting it in again...
Old Jun 28, 2018 | 06:22 PM
ronbros's Avatar
just do it , get going, you would be surprised what little effort can do!
Andreas Schmieg
Nov 12, 2017 07:29 AM
muskox3437
22
Apr 27, 2017 03:08 PM
newtcopa
Jun 15, 2012 03:53 AM
jindracusin
Dec 28, 2011 08:05 AM
