Erratic Gauges
Old Sep 16, 2013 | 07:20 PM
Gator8's Avatar
Default Erratic Gauges
My '91 Classic Collection coupe (5.3L) has an intermittent gauge issue. The tach is fine and the speedo usually is, but the smaller gauges (drum-style) are unreliable. For some time, they have been affected by turning on the lights. Recently they began giving false readings even when the lights were off--specifically, the temp, fuel and oil pressure shoot up while the ammeter drops. When this occurs, if I switch on the lights, all the gauges peg at the upper limit. My mechanic cleaned all the grounds and the situation improved, but on a recent long day of driving, the problem still occurred, especially after I'd been driving for a while. It would rectify if I turned the car off and let it sit. One time, it even "fixed itself" while I was driving. As for the speedometer, it went through a spell of dropping to 0 then reading correctly, then dropping, etc. After several such episodes it was fine the rest of the day. Should I continue to assume the grounds are the issue, or do I need a circuit board--or something else entirely? The temp is my big concern, although recently even on hot days it's running around 190, per my infrared.
Old Sep 16, 2013 | 07:43 PM
Doug's Avatar
Yes, grounds.
Common issue.
Remove the cluster, clean all the circuit board contact points, and add a redundant ground wire to the cluster. You should be good to go after that
Old Sep 18, 2013 | 02:08 PM
Steve M's Avatar
Also check the fuse box (under the drop down panel below the steering wheel on right hand drive cars); I sometimes lose all the instruments but they come back if I prod the fuses in the fusebox.
Old Sep 25, 2013 | 07:39 AM
Scoupe89's Avatar
I would do a free check the alt. at Autozone or other retail store.
My internal reg went bad and fried the alt. giving me weird gauge problems.
X308XJR
May 20, 2019 06:50 PM
workworkwork
Oct 23, 2015 10:26 AM
vwbusbits
Oct 13, 2015 03:43 AM
3lvis
Oct 1, 2015 01:56 PM
