European octane or American octane
Old Sep 10, 2024 | 10:45 AM
daanv's Avatar
Originally Posted by Mguar
American octane is motor method plus research method divided by 2
British octane is just research method. So British 95 octane is a point or two higher than our combined divided by 2 method.
When you add alcohol to the number, it’s rated lower technically then it is. I say pure ethanol has a 105 octane but it’s not really. Alcohol is both higher and lower but not rated by octane.
The engine will ping less with ethanol and run cooler but that’s because it’s a slower flame front.
That means the expansion of gases occurs further down the stroke of the piston.
Long strokes ( 4” ) develop more torque with alcohol all things being equal.
Interesting. First of all, my jag does not ping at all, with 87 and the usual mix with alcohol, usually about 10%, although as you may read in my previous post, I drive it very conservatively and it hardly ever kicks back into a lower gear even in hills with my driving style. Now my question: does driving with the standard bit of alcohol in 87 octane, do better or worse on fuel consumption, particularly at relatively short distance driving (about 20 miles destinations)?
Thanks so much for answering
jww427
Mar 13, 2024 10:48 PM
hofslr
Sep 3, 2021 09:23 AM
gthawk1
Sep 29, 2020 07:29 AM
jagtoes
Apr 22, 2016 07:37 AM
mounty
May 12, 2014 08:30 AM
