extreme rear toe in help
Old Mar 28, 2015 | 03:23 PM
M90power's Avatar
Default extreme rear toe in help
so i was eyeballing my XJS the other day and ive noticed that the rear wheels seem to be towed in very sharply. possibly -2* or more
i cant tell if this is due to the body lines tricking my eyes or if there is an actual problem here. ive never messed with the rear suspension. is there possibly something that could be wrong?
any help guys?
Old Mar 28, 2015 | 04:15 PM
Brake buster's Avatar
the rear can't be adjusted for ' toe ' just ' camber '
probably an optical illusion,
do you have any abnormal tyre wear ?
BB
Old Mar 28, 2015 | 04:34 PM
plums's Avatar
If you look up some of the diy alignment tutorials you can figure
out how to get a fairly good measurement of your toe-in using
just string and a ruler.
BTW, toe-in is positive if the front of the tires are closer together
than the rear of the tires. So, +2* if you are really saying toe-in.
Rear toe-in, unlike front toe-in, must be set equal on both sides relative
to the centerline of the car. This is true of the front as well, but on the
front, if toe-in is unequal it only results in a crooked steering wheel. Not
so with the rear.
I see that BB says rear toe cannot be adjusted. So the above is just
for verification purposes.
Old Mar 28, 2015 | 06:07 PM
M90power's Avatar
ok thanks guys. i had noticed that the rear control arms seemed to be solid, but i wanted to double check.
i havent noticed any unusual tire wear, but ive only had this car running for about two weeks in the last two years.
Old Mar 29, 2015 | 08:24 AM
just to confirm you observations
your saying that you think the front most part of the rear wheel tyres are looking in toward the middle of the car ( toe in ), which can not be adjusted
and you not saying the top of the tyre is looking in ( camber ) , which is normal, and actually advised to remove the camber shims to improve rear planting of the car on the road for a more positive feel
if no scrubbing or grabbing into cornering the car, i would suggest you ok,
if in doubt then take her to a tyre centre and get the alignment checked , advisable after any recommissioning to be honest
BB
Old Apr 1, 2015 | 11:25 PM
M90power's Avatar
yeah i suppose its just an optical illusion. the rear looks toed in but its clear now that its impossible.
the camber is set to 0 which is very dissapointing. ill be removing those shims soon and trying to dial in a few degrees of negative camber.
FrickenJag
Jun 16, 2025 02:15 PM
H20boy
Dec 24, 2024 03:23 PM
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
luc891
XE ( X760 )
Sep 15, 2015 12:30 AM
AtholC
Sep 9, 2015 09:07 PM
