Facelift 4.0 Cold Weather Coolant Temps Needed
Old Nov 21, 2014 | 08:23 PM
Vee's Avatar
Vee
Default Facelift 4.0 Cold Weather Coolant Temps Needed
I have an unusual problem for an XJS...
It seems that my engine does not come up to temperature!
It's been no warmer than 30F here in the DC area and my needle stays left of the N, closer to C.
I checked the temp of the coolant with an IR gun as well as taking readings from the OBD port... 168F
168F!
Is that too cool? I'm asking others who are experiencing cold weather to see how your 4.0 is running.
Old Nov 21, 2014 | 09:01 PM
Doug's Avatar
What thermostat do you have? Whatever the thermostat rating is the coolant should stay *at least* that hot.
I suspect your thermpstat is stuck open
Old Nov 22, 2014 | 01:41 AM
sidescrollin's Avatar
second on the stat being stuck open! It is cold enough that if it is partially open it doesn't overheat but wide enough to cool the engine when it doesn't need to be cooled, causing it to take waaaaay longer to get up to temp.
Old Nov 22, 2014 | 02:44 PM
Vee's Avatar
Vee
I ordered a Wahler thermostat, which comes with the O-ring gasket. I've also ordered the gasket on the other end.
I suppose I'll have to drain some of the coolant out.
What's the best way to do this?
Old Nov 22, 2014 | 03:33 PM
Spikepaga's Avatar
I have done it several times because I am always paranoid about thermostats sticking. Never drained the radiator, just do it fast with the engine cool and a large pan underneath, then refill the reservoir tank.
Old Nov 22, 2014 | 08:04 PM
Yeah you have to pull both hoses anyway, and the only other way to drain it is to pull the main lower hose, so just get a catch pan and let it drain when you pull the hose from the stat housing. Like spike said, ends up draining less coolant anyway
BrentGardner
29
Dec 16, 2024 12:13 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
1100me
Aug 27, 2020 11:37 PM
RaceDiagnostics
Dec 11, 2015 10:12 AM
divingmom
Aug 25, 2015 07:54 PM
