Facelift - Rear Suspension Low on One Side
Old Mar 30, 2021 | 10:19 AM
Greg in France's Avatar
Originally Posted by Vee
I understand I don’t have to do anything now, thank you,
however,,,,
If I did add two shims for each drivers side spring at the rear, and the front, would the body appear level, or am I just going down a complicated path?
If the car is a touch lower on the RHS than the left at both ends (assuming you are measuring to the top of the wheelarch from the ground?) then adding shims will raise the RHS - strangely it will also raise the LHS but not by nearly as much. Although a pain, I would do the front spring first, as you may find the rears are OK afterwards. Only two shims at the front at a time, max, I would suggest. Thinking diagonally, raising the front RHS will put more load onto the rear LHS.
mikewv100
Jun 25, 2021 03:49 AM
brinny
Oct 19, 2020 10:51 PM
Stu Jags
Apr 22, 2020 04:15 AM
gagman66
Feb 18, 2020 10:02 AM
eric7216
Mar 20, 2012 02:31 PM
