Fast idle?
Old Nov 22, 2009 | 01:22 PM
johnlittle01's Avatar
Default Fast idle?
Hey guys and gals. I'm trying to track down the cause of a fast idle of around 1100rpm. So far I have eliminated the extra air valve, throttle bodies and linkage and vacuum leaks. My idle adjustment is turned all the way in so I have no more adjustment left there. My knowledge of the V12 is limited so I'm wondering if I could be missing a sensor or some other component that could cause this. Forgot to mention I also re-torqued all the intake manifolds.
Thanks in advance for any help you can offer.
John
1990 XJS
Old Nov 23, 2009 | 09:52 AM
nosox's Avatar
Hi John,have you checked the coolant temp sensor(beside the left thermostat) and the air temp sensor(left air filter housing trumpet)
Good luck
Les
88 1/2XJ-S
Old Nov 23, 2009 | 12:04 PM
Not yet but I'll check them next.
Thank you......
Old Nov 26, 2009 | 01:03 PM
Default Solved
Culprit was the extra air valve. Cleaned, lubed and reinstalled.
workworkwork
Oct 23, 2015 10:26 AM
tomkilner
Oct 9, 2015 07:10 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
Glenn Barickman
Oct 1, 2015 04:09 PM
