First Time doing Brakes - tips?
Old Nov 5, 2011 | 08:42 PM
cadfael_tex's Avatar
Default First Time doing Brakes - tips?
About to tackle the rear brakes on my '94. This is the first time I've done any brake work. I have the parts (EBC OEM rotors, Akebono pads, fluid, brake cleaner). I have read to open the bleeders when I push back the pistons and have read up on the bleed procedure for the Teves III.
Is there a good write up somewhere? Any hints? Any pitfalls to avoid?
Old Nov 6, 2011 | 10:16 AM
kthrash's Avatar
its easy, make sure you have the proper Torx Socket head..
If you have ever replaced rear brakes with the built in parking brake its identical.. the only issue I found was the car had to be cranked and running to bleed the brakes.
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
obwoodie
Sep 3, 2015 07:45 PM
XFR_Gold
Sep 2, 2015 12:24 PM
