fluid capacities
Old Feb 15, 2010 | 03:55 PM
rama1200's Avatar
Default fluid capacities
greetings all...
after changing sparks/wires, checking what kinda of shape the floor was and all those little things, decided to change the oil...
my explorer 4.0 v6L can fit about 5qrts... after dropping the the old oil in the recycling containing realized that the jag can fit more than 5qrts... so it made me think that may be it was low before and it might fit 8 or 10 qrts...
can someone tell me:
1. how much oil will a 4.0 6I will fit?
2. how much coolant?
3. how much and what kind transmission?
4. how much and what kind rear end?
Thanks a bunch..
Old Feb 15, 2010 | 04:39 PM
ken@britishparts.com's Avatar
1. The engine oil capacity should come in at 9 to 9.5 quarts.
2. Coolant: I just mix 50/50 coolant and water and add as needed. Don't forget to let the thermostats open.
3. Trans: Dexron III. Should be about 5 quarts.
4. Diff: top of the fill hole. Need to find out if you have a power lock or limited slip rear end. If it's limited slip, you need to add Fish oil. Otherwise, normal gear fluid.
Old Feb 16, 2010 | 08:30 AM
rama1200's Avatar
ah... as suspected... so I need more oil...
Thanks, Ken....
one more thing... how do I know which rear end do I have? is there a code branded on/in it? VIN?
RaceDiagnostics
Apr 4, 2016 04:00 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
