front cat. heat shield
Old Apr 13, 2011 | 10:15 AM
expedio2005's Avatar
Default front cat. heat shield
Hi all,
I recently ordered a new front cat. down pipe for my 95 xjs because I thought mine was rotted out due to significant exhaust noise coming from behind the heat shield wrapping around the down pipe. Well by the time my new part arrived I had finally taken off the old one, ripped off the factory heat shielding just to find that a weld was broken. The pipe and cats were fine although now there is no heat shield (which was shot anyway) on my part. I noticed on the new part there is no heat shield either. My car has 60k on it. Does anyone think it's worth keeping the new one and putting it on (for $500) or just welding the old one and putting it back on, knowing it has 60k miles on it and no idea of how many more miles I'll get before having to replace anyway. Without the heat shield on either part, am I going to have heat problems, say with the O2 sensor wires etc. ?
Old Apr 14, 2011 | 02:26 AM
XJSPaul's Avatar
What is the EPA status where you live? In the Peoples Non Republik of Kalifornication you have to pass a smog test every 2 years. If you don't have to do a smog test, I would say save the money, weld the old one.
Keep the heat shield. You need it. You can fry / melt / burn the under hood wires with out it.
XJSPaul
'94 V12 XJS Convertible
Old Apr 14, 2011 | 02:40 AM
plums's Avatar
60K is not a lot of miles for a cat.
You can probably fab a heatshield or maybe muffler shops have generic heat shields available.
edit: just noticed you were talking about around the downpipe. maybe you could use header wrap.
Old Apr 14, 2011 | 04:44 AM
warrjon's Avatar
You don't say if it's a V12 or I6
I would re-install the heat shield. Mine was shot so I wrapped the pipe in exhaust wrap. In the V12 the pipes are very close to the steering rack rubber boots.
Old Apr 14, 2011 | 09:34 AM
It's the I6. I don't see any way of re-using the old heat shield, it was pretty shot by the time I got it off. Will header wrap provide enough heat protection and is there an issue with it getting wet if I happen to get caught in the rain? Has anyone used a manifold blanket before? It almost seems like a good idea maybe to use a combination of a blanket and wrap but then we're looking at $100 or more. I've seen some silicone spray to apply after the header wrap to keep it waterproof. Any comments on that?
Old Apr 14, 2011 | 05:21 PM
Today, I spoke with an exhaust shop and also another mechanic who both said not to worry about the heat shield for various reasons. Does this sound reasonable?
Old May 10, 2011 | 09:19 AM
newworld's Avatar
Default heat shield
listen to marrjon.....earlier post, yes you can talk to as many mechanics as you want and they will tell you what you want to hear......but the exhaust is very near the cv joints on the rack....i have had experience with many cars and the exhuast will "cook" the oil in there and rubber, eventually you are looking at problems....so yes, you can feel better by putting the heat shield in there as the manufacturer did and with reason....and stop asking mechanics who dont know better.....
Old May 10, 2011 | 04:32 PM
worried n confused's Avatar
Jaguar did not put the shields on there by mistake or just for the hell if it! That's like saying a camper dosent need to have safety chains. Your right. They don't have to however I wouldn't go without them
Old May 11, 2011 | 03:26 AM
warrjon's Avatar
The metal heat shield on my V12 LH down pipe significantly reduces the heat radiated into the steering rack gaiter. The wrap I used on the RH down pipe does an even better job of reducing heat around the steering rack column and gaiter. The down side of the wrap is if you do a lot of short trips moisture will not totally evaporate and can cause the down pipe to rust - just keep an eye on it.
I would not leave the heat shield off permanently
cheers
Warren
H20boy
Dec 24, 2024 03:23 PM
kevinl
Oct 31, 2019 06:15 PM
johndahlheimer
Sep 16, 2015 05:44 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
adam699
Sep 12, 2015 05:32 PM
