Front License Plate Mounting Without Bumper Holes
Old May 12, 2021 | 03:57 PM
inertian's Avatar
Default Front License Plate Mounting Without Bumper Holes
Has anyone come up with a workable way to mount a front license plate on a facelift XJS without drilling holes in the bumper for a mounting bracket (e.g., Genuine Jaguar License Bracket HHC6458BB)?
Is it possible to attach the plate (with or without bracket) to the lower grill? I know there are some specialized under-the-bumper devices, but haven't found one specific for the XJS.
Don't need it to be easily removable, just secure and non-destructive to the car.
Appreciate any suggestions.
Old May 12, 2021 | 06:57 PM
garethashenden's Avatar
Don't attach it to the grill, the radiator needs the airflow. There may be some way, but screws are the most reliable way of holding a license plate to a car.
Old May 12, 2021 | 09:45 PM
Vee's Avatar
Vee
Amazon Amazon
Any kind of universal license plate holder will work. I used zip ties to attach it to the lower grille.
Old May 13, 2021 | 09:48 AM
Lagunillero's Avatar
Default Front tag
What I did was rivet an L shaped piece of plastic ( cut from a square bucket) to the underside of the bumper. I think I’m going to replace that with a piece of aluminum though, so it doesn’t jiggle as much.
Old May 13, 2021 | 11:36 AM
icsamerica's Avatar
I use EZ-pass tape or 3M dual lock. Done right and affixed to a clean surface it works great and can be removed and leave no trace.
P/N SJ4580 is specified for in and outdoor use.
https://www.3m.com/3M/en_US/p/d/b40068924/
Old May 20, 2021 | 06:36 PM
inertian's Avatar
Default Went Old School...
...and used some bungee cords for now. Two on top, one on the bottom, through their relative grills. A piece of carpet padding behind the plate prevents it from moving around and keeps the hooks away from the bumper.
If/when I decide on getting personalized plates I'll either fabricate an under bumper L-bracket or give in and attach the correct mounting plate with screws.
Old May 20, 2021 | 06:52 PM
Vee's Avatar
Vee
I wouldn’t call that old school…
Old May 20, 2021 | 10:11 PM
Brewtech's Avatar
Im from the old skool, and I’ve never seen that done before. Get some 3M tape and adhere it to the bumper.
Old May 21, 2021 | 08:13 AM
inertian's Avatar
Default OK, maybe Quick & Dirty and not Old School...
Poor choice of words on my part, forgot who I was dealing with here! Maybe if I had used duct tape?
The goal was to get the front plate on quickly without any damage to the bumper, so I could pull it off when traveling to those states I frequent that don't require it. I actually did the attachment last Thursday evening in preparation for a long weekend of interstate travel. Unfortunately, the Cat developed an issue that night that required it to stay home. Took my less exciting but reliable SUV instead.
Of course all this will likely change when vanity plates happen - why get them and not display them coming and going?
Old May 27, 2021 | 07:35 AM
Vee's Avatar
Vee
This is how it looks when you attach the license plate to the lower grille. I used a universal license plate holder with some zip ties.
Old May 27, 2021 | 10:18 AM
inertian's Avatar
Was thinking of attaching mine in a similar manner, but had two concerns:
  • If plate visibility was hindered enough to cause the authorities to hassle me
  • if plate location blocked airflow sufficiently to possibly cause an overheating issue
Have you experienced either of these issues?
Old May 27, 2021 | 02:24 PM
Vee's Avatar
Vee
No to both questions.
I live in Virginia, where front plates are required. I drive this car everyday, 4 season, all the time. I've never had a cop question the placement.
Old May 29, 2021 | 03:01 PM
Default Well, not visible holes on the painted bumper.
attaches under the bumper.
I only wish the front end sat up this high!
Old May 29, 2021 | 08:05 PM
Brewtech's Avatar
I can still read your plate with see through tape on it😆
VR6Guru
Nov 12, 2014 04:43 PM
Lady K
Jul 3, 2012 05:35 PM
nootherids
Jan 20, 2011 06:29 AM
zachster
Feb 20, 2010 07:44 AM
christer200
May 10, 2009 08:54 PM
