Front lower shock mounts
Old Oct 30, 2019 | 12:45 PM
scottpeterd's Avatar
Default Front lower shock mounts
As I am finishing up the steering rack R&R, I’ve noticed both lower shock mounts are broken where they fit over the lower ball joint threaded stud.
Is this a common problem?
Old Oct 30, 2019 | 03:25 PM
Greg in France's Avatar
The shock lower mount is secured by the outside two spring pan bolts and the lower ball joint nut. If it is cracked or the balljoint tab part of it is broken off, I would replace it or weld it.
Old Oct 30, 2019 | 04:58 PM
We welded it today till I find some used ones
apexjag
Sep 24, 2019 12:52 AM
michaelh
Aug 7, 2019 07:31 PM
grantorino62
Nov 17, 2016 08:07 AM
Jim D
Jul 13, 2014 05:33 PM
cjd777
May 23, 2014 09:04 PM
