Front shock bushings, which one?
Old Nov 9, 2015 | 02:40 PM
Alexv12's Avatar
Default Front shock bushings, which one?
I need to replace my upper front shock bushes because my 91 still has the originals and I get the clinks and clanks over bumps.
In looking at this picture, what are the black bushes and the yellow ones? The blacks are simply "shock bushings", while the yellow are the "upper bushings"?
Thanks for the help
Old Nov 9, 2015 | 05:13 PM
bullittandy's Avatar
I believe the black ones are lowers and yellow ones are uppers.
Old Nov 9, 2015 | 06:39 PM
Dymaxxion's Avatar
I'm probably about to do this as well on my '83. From what I understand the yellow rubber ones are factory Jaguar and the black are an upgrade to Poly. Hopefully someone else can chime in.
Old Nov 10, 2015 | 09:22 AM
TweeTwee's Avatar
Sorry I don't have any information to add but if you are up for it I'd LOVE a step by step post on this job after you do it. Thanks, and good luck!
Old Nov 12, 2015 | 03:05 PM
warrjon's Avatar
Those are Bilstien shocks in the pic. I put these in my car and with a 25mm front sway bar sharpened the car up dramatically.
The black go between the shock and the tower and the yellow under the nut. These are an upgrade to the OEM Jaguar units, but not as hard as rubber or Poly.
Do not use Poly anywhere in the front suspension (except the rack and maybe sway bar), you will regret it unless you race the car and NVH is of no concern.
Papelione
Jun 23, 2016 07:05 AM
NtAFord
Feb 16, 2016 01:05 PM
guy
Nov 20, 2015 11:48 AM
RFXJ12
Nov 5, 2015 10:09 AM
Poppyboy
Nov 4, 2015 03:07 PM
