Front suspension wishbones etc - bolt/nut sizes
Old Feb 7, 2020 | 09:53 AM
Asdrewq's Avatar
Default Front suspension wishbones etc - bolt/nut sizes
I really dislike imperial measurements . After lots of measuring & googling I think i've figured most out - hope this helps someone. Can anyone help fill in the gaps in red? This is for a 1989 XJS if that makes a difference - I think some of these might have changed over to metric at some point.
Upper wishbone
Upper fulcrum ends to hold in upper wishbone bushes - 1/2" UNF
upper fulcrum > subframe nut - 7/16" UNF
upper fulcrum > subframe bolt 7/16 UNF x 2 1/4"
Upper balljoint mount nuts - 3/8" UNF
Upper bumpstops thread - 5/16" - 24 UNF
Upper balljoint mount bolts - unknown lengths - long/short
Upright/Lower wishbone
Stub axle - 5/8" UNF on both ends - nyloc on rear.
Spring pan>wishbone nuts/bolts/studs - 3/8" UNF
upright > lower balljoint bolts - still available as 'special bolt' w/ loctite.
lower shock to mounting bracket bolt/nut - 7/16" UNF
lower bumpstop nuts - ???
3x lockwired caliper bolts - ???
Also any others that any one knows when replacing the front suspension - steering rack/ARB mounts/links/engine mounts/engine mount supports/power steering cooler etc would be very useful!
Old Feb 7, 2020 | 01:12 PM
Greg in France's Avatar
There are only two caliper bolts (they are lockwired), the third bolt is steering arm to upright. The bolts are metric fine, NOT UNF. Sorry i cannot remember the size.
Old Feb 7, 2020 | 02:04 PM
Asdrewq's Avatar
Thanks Greg, I think i'll reuse the ones I removed - I don't think they were in terrible condition (unlike the upper balljoint bolts that I had to cut off & binned!
Found another - lower shock to mounting bracket bolt/nut - 7/16" UNF
Old Feb 7, 2020 | 02:48 PM
lasstss's Avatar
I replaced all my front hardware on a 1995. Caliper bolts were M12-1.25 got them from Belmetric.com. No wire holes....I use teflon thread locker. Cheap and all yellow zinc plated.
US bolts I got from Mcmaster Carr. Bump stops 5/16-24
sunchip
Feb 24, 2017 04:51 AM
JohnJonesXtype
Jan 6, 2017 11:00 AM
rowland
Aug 15, 2015 05:49 AM
MCW739
Jan 5, 2014 05:02 PM
Pilkie
Jul 9, 2011 02:14 PM
