front wing removal
Old Jul 16, 2024 | 08:15 AM
malc4d's Avatar
Default front wing removal
Trying to remove the front wing 1993 coupe. Any information would be really helpful. I've found a couple of youtube videos but they dont show the complete removal.
Old Jul 16, 2024 | 08:28 AM
Greg in France's Avatar
IF, big if, it is that same as pre facelifts, it just unbolts EXCEPT where it connects to the front low quarter valence, which it is braised to. It MIGHT be that this join is bolted on facelifts.
To remove the wing this braised join has to be separated. Apart from that proceed as follows (but this is pre facelift so your car might be a bit different)
  • there are two VERY hard to get at bolts just inside the wing top at the door end, which can JUST be accessed from the gap the door leaves when the door is removed.
  • remove the wheel arch baffle at the rear of the wheelarch to reveal bolts holding the wing to the sill/bodywork
  • undo the front baffle and remove
  • undo the line of self tapping bolts along the engine bay gutter
  • remove the headlight unit and trim to access bolts in the nacelle area
This leaves the wing free, except for the braised joint (on pre facelifts at least) at the lower wing in front of the wheelarch where it joins the lower quarter valence.
Old Jul 16, 2024 | 08:38 AM
Those bolts Greg mentioned first up are able to be removed with the door ON the car.
1985 Coupe.
NOT EASY, MANY, MANY words uttered, and too many beers consumed.
I considered taking the door off, NOPE, there had to be a way.
Again, as Greg said, your 93 may be different/better, dunno.
Old Jul 17, 2024 | 01:48 AM
Also, from memory, I think that there are wing to quarter panel attachments (in addition to the braised joint) hidden by the bumper where it goes round the corner from the headlight and back to the wheelarch.
Old Jul 25, 2024 | 10:43 AM
BenKenobi's Avatar
There are and the screws are installed in such a way that straight on access is a nightmare. The yellow lines in this image are my recollection - be careful with the very front the piece under the headlight is also brazed on but there is a small screw that can catch you out - and if you bend this making it look right again will be no fun at all - there is no alternative with the brazed joint but either melting the joint or cutting - either way you will be painting.
This image is from three years ago hence the memory deficiency - there may be one less on the front than I have indicated. The ones at the lower rear can fight you - don't attempt them with anything less than a 6 sided socket - if they round out you are going to be fighting in a really cramped and uncomfortable place - the wing could equally be rotted off here ....
Old Jul 26, 2024 | 06:21 AM
EvertXJS's Avatar
There's 3 more bolts: indicated with arrows on the vertical post that holds the hinges as well. You shouldn't need to get them out completely, they connect to slotted holes in the front wing.
3 more bolts. Accessable after removal of stoneguard
ppsales
Jul 13, 2022 10:20 AM
T26_SYK
Oct 30, 2021 01:48 PM
wasaloadie
Aug 26, 2017 04:47 PM
Shadow993
Dec 21, 2016 08:09 AM
