Fuel level sending unit?
Greetings. My XJS fuel gauge / fuel level sending unit is acting erratic. After I fill up to a full tank, the gauge will rest at about 80% full. The gauge will quickly go down to 25 to 40% full after a few days of short driving. Then, if I go downhill (i.e. into a deep circular underground carpark) the empty warning light comes on. Once I reach level ground at the bottom of a car park, the gauge goes back up to 25 to 40% full. When I go to fill up, the car is usually more than half full.
Is this likely a problem with fuel level sending unit?
Many thanks,
Charles
Many thanks,
Charles
Charles,
On facelift cars, it's as, if not more, likely to be an issue with the anti-slosh module. Over time, they start to "leak" current and the gauge drops quickly. Try bypassing it and see if the gauge returns to a steady state. If you don't know how to do that, post back and I'll explain.
Paul
Paul
