fuel pressure
Old Aug 29, 2008 | 07:53 AM
ontherun's Avatar
Default fuel pressure
I have a bad "bog down" situation happening with our 90 XJS 5.3 ,.how would you check the fuel pressure at the rails..or at the regulators..I can put a inline gauge at the pump...it feels like it's starving for fuel..also what should the pressures be...from the pump and at the injectors?. any input would be helpfull. thanks in advance....L
EDIT: just serched the sight,. should of done this first,... somebody posted about the surge tank between the tank and the pump...the tank was replaced in 04 but I'm going out to clean the small holding tank to see what I can see...would still like to know the pressures though....Thanks again
Old Aug 29, 2008 | 06:48 PM
ontherun's Avatar
Default RE: fuel pressure
found a bad coil fixed it..changed tps. new wires and plugs, fresh fuel, still bogging down bad....might have to let the Jag Gurus look at it....L
Old Aug 30, 2008 | 05:44 PM
jag_genius's Avatar
When is it exactly bogging down?
Old Sep 4, 2008 | 09:19 AM
ontherun's Avatar
It would bog down anything after idle..but, we took it to the local Guru and they had it fixed in no time...I can say that I don't know crap about these cars..I can act like I do and just throw parts at it,....but, I was close....it was the rod adjustments and AAV it now idles at 700 and thebog is gone, cost me $110.00... should ofgone there first....live and learn....thanks for your help....oh ya the surging is gone also....L
Old Sep 8, 2008 | 07:15 PM
ontherun's Avatar
All the problems came back except the idle, it's great,...step on the pedal and it falls flat on its face,...went the direction I was headed in a while back,.. drained the tank, run the car until it ran out of fuel, touched the fuel pump and it burned my finger,.that aint right,.changed the pump and it runs like a scalded dog,.. I can hear the tires trying to catch up with the motor, and G-forces I've never felt from that car...wow..I like it now....I'm
out...L
Old Sep 9, 2008 | 12:45 PM
ken@britishparts.com's Avatar
Do yourself a favor and change the fuel filter several times. The tanks like to rust and take out the fuel pump. Unfortunately, the fitler is after the pump, but this way it won't have to push through the collected crap. If you take this pump out too, be prepared to pull the tank.
Old Sep 17, 2008 | 07:16 PM
ontherun's Avatar
Thank you,. I have receipts saying the tank was replaced 2 years ago. and I cleaned the tank and resivoir with the new pump...don't want to do that again...L
toronadomike
Jan 22, 2026 10:13 PM
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
Papelione
Sep 21, 2015 06:13 PM
ccfulton
Sep 20, 2015 05:15 PM
