Is this a fuel problem?
Old Aug 11, 2014 | 01:28 PM
downsouth's Avatar
Default Is this a fuel problem?
Folks,
I have a '95 XJS 4.0 LHD. 2+2 conv, Automatic, with about 57,000 miles. Good condition overall. have owned it for about 4 months.
In the last two-three weeks I've noticed that when the tank gets down to about 1/3 or 1/4, the car (sometimes) bogs out, loses power and even stalls. Then I fill the tank (93 octane) and the problem goes away. Sure feels like a fuel starvation issue. Any ideas?
bad fuel at the bottom of the tank (drain the tank)?
clogged filter?
weak fuel pump?
Any thoughts?
Ed
____________
95 XJS
69 XKE
70 Stingray
81 928
Old Aug 11, 2014 | 01:58 PM
XJSFan's Avatar
Sounds like a fuel filter and/or fuel pump... I would first try a new fuel filter.
Old Aug 12, 2014 | 01:08 AM
Mkii250's Avatar
Could well be the fuel level sending unit. I think you're running out of gas at 1/3-1/4 indicated.
Old Aug 12, 2014 | 05:17 AM
Vee's Avatar
Vee
Good point. Are you tracking how much fuel you're adding to the car when you're refueling?
Old Aug 12, 2014 | 10:23 AM
downsouth's Avatar
Good point about the fuel sender -- but I tracked the fuel and there is plenty of gas.
Old Aug 12, 2014 | 10:28 AM
downsouth's Avatar
I have a theory and time will tell if it's correct. I suspect there's water (or some sort of contaminant) in the fuel. Here's why:
1) The car stalled or bogged after a hard turn or a hard brake, which might result from mixing the contents of the tank and, thus, stirring up the water from the bottom of the tank toward the fuel intake.
2) I use 93 octane. I wonder whether that fuel is more prone to water problems because so few use it. It sits in the gas station's storage tanks. After all, I live in Louisiana and humidity here is brutal.
I put in some HEET, which is mainly isopropyl alcohol, to absorb the moisture. Let's see what happens.
Old Aug 27, 2014 | 08:28 PM
downsouth's Avatar
Default Is this a fuel problem....SOLVED
Okay, I think my hunch was right. The bogging and stalling was due to moisture in the tank; I must have picked up some bad fuel in this humid place (Louisiana).
I put in a (RED) bottle of HEET, which apparently is 99% Isopropyl alcohol, and that improved things. Later when the fuel tank was 1/2 empty, I put in a second bottle.
Two weeks and two tanks later, the problem seems to have disappeared.
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
OkieTim
Sep 8, 2015 04:48 PM
alpecsa
Sep 7, 2015 11:55 AM
AL NZ
Sep 4, 2015 08:39 PM
