Fuel Pump
Old Jun 2, 2015 | 08:58 AM
hunterpedigo's Avatar
Exclamation Fuel Pump
My fuel pump is not getting power. My Jag 1995 VP, wouldn't start. Kept turning over but wouldn't start. My mechanic friend says the pump is good but he had to run a wire from the battery to the pump to get the car started and off the side of the road. Any suggestion to what the problem is?
Old Jun 2, 2015 | 11:22 AM
melhookv12's Avatar
Fuel pump relay located in the boot fuse box. not 100% sure which one but I'm sure google will throw up which one it is
Old Jun 2, 2015 | 12:00 PM
hoodun's Avatar
Replace the relay with a sealed one.
Old Jun 2, 2015 | 08:17 PM
I agree with the relay.
Also, it might pay to post this in the X300 section. The XJ-S's of that era are simlilar, but not exactly the same.
Old Jun 3, 2015 | 07:09 AM
Paul_59's Avatar
Banned
Also beware if you have a V12 of that vintage (93 to 97) there are two fuel pumps one runs all the time and a second pump is controlled to run when engine rpm is above 2850rpm
Old Jun 7, 2015 | 10:43 PM
Thanks for the feed back forum, The issue is resolved, I put it back together and it was the Fuel pump relay.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
JWheeler
Nov 22, 2019 08:28 AM
ccfulton
Sep 20, 2015 05:15 PM
Sprayall
Sep 3, 2015 07:49 PM
