Fuel pump
Old May 1, 2023 | 10:54 PM
Rob,
Taps, NAH, not in the boot. Been there, done that, with the PreHE's, always an odour.
Outside the car, sweet.
Mine all ended up like Greg's, with no sump filter. Also used Wix brand, and changed every 5 years, just because.
1/2" hose was the hardest, the 12.5 I was always being supplied just did not fit good enough for me. Goss had it, but that was 25+ years ago.
Old May 2, 2023 | 12:47 AM
Greg in France's Avatar
Robbo
I used this from the USA for the feed hose. You cut out of the shape what you need!
https://www.ebay.com/itm/Universal-1...-/163887361954
Old May 6, 2023 | 01:50 PM
Robbo D's Avatar
Hi guys.
I spent the day pulling the sump tank out etc. This is the sock filter as removed.
Nothing much really. I have now cleaned the tank and done away with the sock filter but have fitted an inline filter between the main tank and the sump tank. The filter I used is actually for tractors FF5289 which is the same as the WIX filter.I have also fitted a new pump and main fuel filter. New regulator’s going on tomorrow. I will report back tomorrow when they are fitted.
Rob.
Old May 7, 2023 | 08:50 AM
Robbo D's Avatar
All done new regulators fitted. This is now my setup for the sump tank.
Now shouldn’t have to open the sump tank again. Just change the inline filter every so often a lot easier than pulling the sump tank out.
Rob.
Tius
XF (X260)
Jul 29, 2024 06:57 AM
twocross
Jul 4, 2020 05:36 PM
RJ237
Apr 11, 2014 07:16 PM
wrightbenz
Oct 2, 2012 09:59 PM
Tom Hite
Aug 13, 2011 05:45 AM
