fuel rail height
Old Nov 18, 2012 | 04:54 PM
J_C_R's Avatar
Default fuel rail height
My fuel rail is about 3/4" higher on the right side than the left side. Not really a big deal except that it's rubbing against the brand-new hood liner I just put in.
Any reason not to lower it so it's even on both sides?
Thanks,
John
1987 XJS V12, 62,000 miles.
Old Nov 18, 2012 | 05:03 PM
Doug's Avatar
Bent?
Unequal length hoses to the injectors?
Old Nov 18, 2012 | 05:45 PM
J_C_R's Avatar
Ummm...no, nothing looks bent. Just looks like someone elevated (or shortened) one side.
Should there be any issue caused by making all the hoses the same length?
John
Old Nov 18, 2012 | 06:39 PM
Doug's Avatar
John
Not at all. They *should be* all the same length except, of course, the two forward most hoses which are longer so as to reach the injectors.
I recall 1.75" hose length for the 10 hoses along the sides and 2.75" for the two front hoses....but my memory isn't always all that it should be :-)
cheers
Old Nov 18, 2012 | 06:40 PM
Doug's Avatar
Another possibility is that the injectors on one side are not properly seated into the inlet manifold
Old Nov 19, 2012 | 06:16 AM
J_C_R's Avatar
DD, the hose height on the tall side are 2.5", and more like 1.75" on the other side.
Since I have to pull the fuel rail, sounds like a good time to remove the air rail too. Anything else useful I should do with those parts off?
Thanks!
John
1987 XJS V12 62,000 miles
Old Nov 19, 2012 | 06:48 AM
Doug's Avatar
Thanks!
John
Yes! But it'll take some time and effort....
This is a prime opportunity to "do the Vee". That is, remove/service/repair/clean everything that resides in or near the "Vee" of the engine all at once while you have clear access.
-Replace plugs, plug wires, dist cap and rotor
-Check/repair distributor vacuum advnace and mechanical advance
-Replace vacuum hoses
-Repair wiring that has been baked to a crisp from egnine heat
-Replace/repair fuel injector wiring harness
-Replace fuel hoses
-Replace leaking oil pressure switch and sender
-Replace throttle bushings
-Repair/reseal cruise control bellows
-Repair/replace/adjust kickdown switch and enrichment switch
-Replace distributor vent hoses and filter
-Synchronize throttle linkages
-Clean away years accumulation of grease and dirt
It's a rare XJS that doesn't need attention in most or all of those areas and it is SO much more practical to do it all at once....and then forget about for the next few years.
If your cam cover gaskets are leaking replace them as well....and your 75% along as far as labor goes
ogorir
Jan 18, 2016 10:09 PM
DaveInVA
Sep 25, 2015 04:43 PM
reb1999
Sep 25, 2015 10:00 AM
Papelione
Sep 21, 2015 06:13 PM
TheWarlock
Sep 20, 2015 03:22 PM
