Fuel smell
Old Jul 8, 2023 | 10:11 AM
brinny's Avatar
Default Fuel smell
Afternoon all,
Took the car for a blast in the sun yesterday and as well as an ignition problem I started getting a whiff of fuel in the cabin. Car has had a major overhaul including all new fuel lines and injector rebuilds. I know I’m going to have to look at all the connections and make sure nothings loose. Can I just give the injectors a little nip up too? I did notice car was running a little juddery at low revs. Any suggestions on where to start appreciated.
Old Jul 8, 2023 | 12:31 PM
Greg in France's Avatar
Brinny
What is the state of your seal along the top of the firewall/bonnet closing line? If you were to drive without this you willl find a HUGE smell of fuel on taking off after (say) a stop at the lights. This is a characteristic of the engine. You might, with the top down, be getting the smell this way. Top up it may well not be evident.
Old Jul 8, 2023 | 08:53 PM
brinny's Avatar
Hi Greg, first time I have noticed it and it is first time I've had the hood down. Seal is new. Smell is noticed more when I pull up after a run. Also got a bit of a judder but tick over is a bit low. Will have a look around on Monday.
Old Jul 9, 2023 | 08:04 AM
BradsCat's Avatar
Do you have any fuel smell when you open the trunk/boot?
Old Jul 9, 2023 | 09:29 AM
brinny's Avatar
Yes, but I put that down to the car being sat with a cover on. I did notice a much bigger whoosh when I fuelled up the other day and opened the cap, but put that down to the fact it was hot. I've replaced all the lines and a new rochester valve.
Old Jul 10, 2023 | 07:53 PM
Brewtech's Avatar
How full is your petrol tank? I have a strong smell of fuel in the cabin and trunk every time I fill it too close to the seal at the top of the tank. Feel around and look in that area. If its slightly wet or smelly, that’s your culprit. I personally dont mind, its what all XJS have smelled like due to that design. But if the vapors are coming from the front, you have a problem that needs immediate attention. How good is your nose? Mine usually knows where to look and it can pick up fuel smells.
kstevusa
Mar 2, 2022 11:13 AM
david.bunting56
Feb 21, 2022 04:49 PM
CharlesHK
XJ40 ( XJ81 )
Feb 27, 2021 01:26 PM
razorboy
Feb 28, 2020 11:54 AM
mikemrmike
Apr 25, 2014 07:40 AM
