GKN Diff - just how do you change the seals/bearings?
Old Feb 11, 2012 | 11:19 AM
texasscot's Avatar
Default GKN Diff - just how do you change the seals/bearings?
Hi all,
After finding my 1990 conv. diff had run out of oil , i pulled out the whole back end and removed the outputs (5 bolts) from both sides of the diff. One side was shaky indicating some bearing wear and the seal was shredded.
I will be receiving bearing kits in a couple of days but...
I can easily remove the inner bearing from the removed parts but the outer bearing is captive in the removed housing as it is larger in diameter than the hole at each end.
I can't find any advice anywhere on the fine detail of replacing the bearings and seal. can anyone shed light on this for me? Photo of the offending object included.
Many thanks
Attached Thumbnails GKN Diff - just how do you change the seals/bearings?-img_20120211_104744.jpg
Old Feb 11, 2012 | 01:35 PM
motorcarman's Avatar
If you don't have a shop press, then you can take the parts to a machine or auto shop and have someone press the shaft from the bearing and seal housing. Install a new seal and press the outer bearing back onto the shaft.
I usually place the new collapsible spacer on the shaft and very slightly 'crush' it with the shop press (just BARELY start the bend at the crease). This makes it easier to get the other bearing and thin nut tightened down without applying enormous amounts of torque to that thin nut trying to get the spacer to collapse at the center crease.
The correct pre-load is important.
bob gauff
Old Feb 11, 2012 | 02:51 PM
warrjon's Avatar
There will be shims between the bearing and hemisphere centre note where these go and put them back where they came from. You may still need to re-shim to set the pinion engagement, this is a PITA as you need to press the bearing off and on to change the shims.
Old Feb 12, 2012 | 09:51 AM
texasscot's Avatar
Sounds like I'll have to drag the lot to a proper mechanic!
If anyone knows a Houston, TX based shop that has done this before then i'd be interested. Sounds like too much can go wrong here!
Many thanks for the advice
regards
graham
Old Apr 6, 2012 | 05:25 PM
texasscot's Avatar
Just to close this thread out (sorry for the long delay...).
I got the seals changed out on the outputs by a very good shop in Houston for $300.
For amusement, the first quote i got from a very odd gentleman in another shop in Houston was over $800 (and he wouldn't use any parts i supplied). He actually fired me as a customer for questioning the price!
Anyways, car rolling once again and thanks to all who helped.
Regards
FrickenJag
Jun 16, 2025 02:15 PM
Matei Dima
Oct 8, 2015 11:45 AM
Gerard Radimaker
Sep 13, 2015 10:33 AM
AtholC
Sep 9, 2015 09:07 PM
1100me
Sep 7, 2015 06:26 AM
