Hanging hinges - how to sort?
Old Aug 24, 2014 | 02:38 PM
Daim's Avatar
Default Hanging hinges - how to sort?
Hi all,
My Iron Lady (89 coupé) has a drivers door, which drops about 4 mm when opening in. You notice how much it hangs, when looking at how the door closes. There is slack in the upper hinge, so I assume it is really badly worn. What is more likely to wear out? The pin or the hingebrackets? Is there a fix to this, other than removing and replacing the hinge? Do later style hinges (convert. and facelift) fit? With fit I mean plug and play?
Cheers for some hints!
Damien
Old Aug 24, 2014 | 05:38 PM
superchargedtr6's Avatar
Have you checked to see if there is really play in the hinge? What I'm getting at, is that my doors were both out of adjustment, alignment. When I shut the door, the strike was compensating for poor adjustment by actually lifting the door as it shut.
Once I determined that my hinges didn't have play in them, I took the strike out of the jamb altogether. I removed the interior footwell panels, and using rags, a block of wood, and my trusty floor jack, I adjusted the door until it shut properly without actually latching. After I had this correct, I re-installed the strike, and adjusted it exactly right, and I have to say, both doors now shut with great ease, and don't change at all when when opened and shut.
Poet
Feb 7, 2025 02:18 PM
Dave1109971
Dec 15, 2015 06:16 PM
LnrB
Oct 13, 2015 12:45 AM
rgp
Oct 1, 2015 02:55 AM
vwbusbits
Oct 1, 2015 01:17 AM
