Hard Starting XJS V12
Old Apr 15, 2017 | 10:14 PM
MIFoodie's Avatar
Angry Hard Starting XJS V12
HI. I have joined the forum and am hoping for some help with this issue.
I have Jaguar XJS-V12 from 1990. It is hard to start and I need to give it gas in order to keep it from stalling. If I do that for about 30 seconds or a minute it then idles smoothly on its own.
Any idea what could be wrong? Is this affecting the performance once it gets warm?
Thanks for any help.
Old Apr 15, 2017 | 10:35 PM
Oops,
Your in the S Type section and they are waaaaaaay more advanced than any XJ-S, and they miss out on the mighty V12 engine also.
The XJ-S section will have the answers for your Marelli car, as there is a very long list indeed.
Old Apr 16, 2017 | 07:55 AM
aholbro1's Avatar
I believe Grant is talking about here:
https://www.jaguarforums.com/forum/xjs-x27-32/
Old Apr 16, 2017 | 10:45 AM
MIFoodie's Avatar
Default Hard Starting XJS-V12
Thanks guys !!
Old Apr 16, 2017 | 10:47 AM
MIFoodie's Avatar
Old Apr 16, 2017 | 11:16 AM
Doug's Avatar
Hi
The 'could be' list is long.
Just to get the ball rolling.....
To clarify, does this occur only on cold starts; ie, after sitting over night? If so, one of the usual suspects is the coolant temp sensor...which pays a major role in controlling fuel mixture on a cold engine.
Actually, the coolant temp sensor can cause starting problems on a warm engine as well, if it erroneously sends a 'cold' signal to the ECU (computer) when the engine is cold at all.
How's the general state of tune? Spark plugs, distributor cap, etc?
Old Apr 16, 2017 | 12:06 PM
joycesjag's Avatar
I have asked the powers that be to relocate to proper directory.
Old Apr 16, 2017 | 12:27 PM
MIFoodie's Avatar
The status of the tune is good with new plugs and rotor but not wires. This happens when the car is cold and I never had the opportunity to start it when it was warm.
Old Apr 16, 2017 | 12:56 PM
Mac Allan's Avatar
How long have you had the car?
The reason I ask is you have a 27 year old car with only 29K miles. How much has it been driven recently? When was the last time the gas tank was filled? When was the last time it started without issue?
Old Apr 16, 2017 | 12:58 PM
Jagboi64's Avatar
I'm guessing the axillary air valve is stuck closed and isn't letting in enough air for cold idle. It's on the water rail, left side of the engine at the rear.
It's somewhat similar to a thermostat, except the wax capsule moves a piston that covers or uncovers a port to allow air through. Over time the piston can corrode and quit moving. There used to be rebuild kits available, but I don't think so anymore. If you search here under "AAV" or the full name you should find lots about them.
Old Apr 16, 2017 | 02:28 PM
Originally Posted by MIFoodie
..... I have Jaguar XJS-V12 from 1990. It is hard to start and I need to give it gas in order to keep it from stalling. .....
I've moved your question from S-Type forum to XJS forum. This is the place to post technical questions about your model.
Old Apr 16, 2017 | 06:20 PM
MIFoodie's Avatar
I purchased the car in May of 2015. The car starts but it takes a few pumps of the gas to get it going and you need to hold down the gas to keep the RPM up for about a minute. Then it runs fine. I drive the car in the summer but only put about 1000-2000 miles a year on the car ( I have 2 other collector cars so I just don't have the time to run each of them a lot). It also is not my daily driver. I keep the gas tank full with premium all the time and put in a gas stabilizer during the winter when it is a closed storage facility. I start the car every two months and bring it up to normal operating temperature throughout the year.
Thanks for the tips.
Old Apr 16, 2017 | 07:41 PM
orangeblossom's Avatar
Hi Mi Foodie
This is a Pic of the AAV Valve and as Jagboi says they can get Stuck through lack of use but having said that some people either disable them or else take them off the Car altogether.
All those higher Start up Revs, just help to guzzle Gas, as if She wasn't Juicy enough already!
This is the AAV Valve, which can get Stuck and cause 'Hunting' through lack of use.
Old Apr 16, 2017 | 08:23 PM
AAV is jammed shut.
This might help.
AAV rebuild procedure.doc
Next on my list would be the "black goo" that builds up around the throttle discs. Simply wipe them clean with a solvent soaked rag at each oil change period.
Old Apr 17, 2017 | 02:38 AM
I've merged your two separate Hard Starting XJS V12 threads.
