Harness tranny/oil pressure sensor/... rebuild!?
Old Oct 8, 2016 | 12:07 PM
Daim's Avatar
Default Harness tranny/oil pressure sensor/... rebuild!?
Hi there!
As I am preparing my engine and tranny for a refit (which will happen next year as it looks now...) I noticed, that the rear harness, the one that connects the oil pressure sensor, reverse switch and co (I think the kickdown switch aswell!?) is extremely brittle and is cracking.
I can't find/locate the correct parts number. Is this available new or must I rebuild it? I doubt it will be a problem to rebuild, but I want to try to keep it original...
What are your opinions?
Damien
Old Oct 8, 2016 | 12:18 PM
ptjs1's Avatar
Daim,
I think that's DAC1673, sadly NLA from Jaguar at present.
Paul
Old Oct 8, 2016 | 04:06 PM
warrjon's Avatar
Damien, you can rebuild the harness yourself. Use GXL wire, which is a higher temperature automotive wire that won't go brittle.
Cut the wires from the connectors about 50mm from the connector. Cut some heatshrink tube and strip the wires about 15-20mm and solder them together.
DO NOT use electrical tape to wrap the joint, use heatshrink. Tape will eventually come off.
Here is a good video on how to join wires. I use both methods depending on the wire type, thicker wire I interlock and thinner wire I twist. I also use needle nose pliers as soon as I have soldered to lightly squeeze the solder joint, this does 2 things, 1 cools the joint quickly reducing the heat soak into the insulation, 2 removes and sharp bits that may pierce the heatshrink.
Old Oct 8, 2016 | 04:29 PM
Daim's Avatar
What would you say to updating the connectors whilst at it? I would replace the old round plug with an appropriate sized AMP superseal or even with a couple... I know some parts are just cable shoes but otherwise the rest is kind of unique plugwise...
Old Oct 8, 2016 | 05:46 PM
warrjon's Avatar
If its inside the car I use a general purpose automotive connector, these are cheap and reliable if not subject to weather and dirt.
Outside I would definitely use a sealed automotive or military connector.
I replaced these a few years ago as they were full of old coolant from a leaky heater core.
Attached Thumbnails Harness tranny/oil pressure sensor/... rebuild!?-p_20160822_120752.jpg
Old Oct 9, 2016 | 03:08 AM
Daim's Avatar
These are all in the enginebay. So waterproofing is of course a must do...
Johnken
Sep 2, 2016 03:52 PM
wcourt3010
Sep 2, 2016 12:40 PM
Peter Jones
Aug 24, 2016 08:12 PM
Pana89
Aug 24, 2016 12:10 PM
bcucharternet
Aug 24, 2016 06:32 AM
