Has anybody found a replacement for this part?
Old Dec 23, 2014 | 12:04 PM
Spikepaga's Avatar
Default Has anybody found a replacement for this part?
It's what holds the knee bolster for the driver side in place, for facelift cars. Number 10;:
Old Dec 23, 2014 | 12:13 PM
RagJag's Avatar
I simply replaced it with an auger shaped dry wall fastener with an appropriately sized screw. It is not visible from the drivers seat anyway. Works fine.
Cheers, RagJag
Old Dec 23, 2014 | 01:08 PM
Japthug's Avatar
It is used in the roof console of X300/X308, so you can easily find a used one if you check a salvage yard.
Or maybe you can ask some Jaguar dismantler with the part number BBC9868.
Old Dec 23, 2014 | 01:45 PM
swayne's Avatar
Don't know how big the piece is but both Carquest and Napa have good assortments of those type plastic inserts feel sure you could find one that would work. Check the rack that has the "Help" items on it first. If you can't find something on that rack they should have a catalog. The catalog will be for Al Ve Co (sp) products
Old Dec 23, 2014 | 06:55 PM
Bc xj's Avatar
I agree. Go to Napa of whatever parts place you have close. Chances are the will have something very close and not 20 year old brittle part thats no better than yours.
Old Dec 27, 2014 | 10:25 AM
JagCad's Avatar
Ideas:
1. Genric plastic insert for license plate fasteners.
2. Maytag dryer door catch.
3. XJ6 cubby lid latch. Same issue, pold and brittle plastic.
4. Bend up some sheet metal and drill a hole in it.
Carl
X_Type_South_Africa
Dec 9, 2015 05:37 PM
casepie
Aug 30, 2015 09:49 PM
perfectphoto
Aug 29, 2015 10:11 PM
dpappyp
Aug 27, 2015 06:31 AM
innzane
Aug 26, 2015 08:41 PM
