Has anyone retrofitted coilovers?
Old Apr 12, 2020 | 03:04 PM
Drew1987's Avatar
Before I do it, I will send a picture just to make sure I have “calculated“ the right spot LOL
that is super cool that they used such an old engine… Well designed engine is a well-designed engine… I bet an old Chevy 235 with modern tolerances And fuel injection would be substantially better than any of the six cylinders they made today LOL I believe the four-cylinder and Volkswagen Jetta is a 1992 design with modern components. This jagged front and uses a 4.9 inch inner diameter coil that’s about 11 inches high free height. I have searched and searched and still not found any other vehicle that uses a similar sized Coil. I was hoping to find something with a spring right around 340
Old Apr 12, 2020 | 03:53 PM
ronbros's Avatar
Drew , the Chevy 235 was /is a low performance engine , the GM inline 6 to mod would be the GMC truck engine!
full pressure lube system, 7 main bearing crank, cross flow Ally head available,etc! many manifolds and performance parts available!
the ultimate inline 6 would have to be the BARRA 6 from Australia, 300cu.in. all forged internals from factory, modded some have been over a 1000hp!
Old Apr 12, 2020 | 04:11 PM
ronbros's Avatar
rear body flex area, this stiffins it up!
pic of my cross brace on XJS that is a cross the upper body above the shocks, it does stiffin up the body structure , along with the diagonal braces , also there is a front cross X type front of radiator!
it is surprising how much flex is in the XJS unibody, pic of rear section that can flex(i think this got it covered now).
Old Apr 12, 2020 | 08:25 PM
Drew1987's Avatar
I only meant reliability. Performance would be the 194-230-250-292. Those were better. I just meant old motors were actually good. With today’s tech they’re likely better then today’s crap. I love that jag rocked a wwii motor in the 80s. I loathe that Toyota didn’t use the 90s JZ In the new Supra.
razorboy
Aug 21, 2019 03:18 PM
michaelh
Aug 7, 2019 07:31 PM
dannio636
Apr 8, 2019 12:38 PM
Chuck Schexnayder
Apr 30, 2018 07:23 AM
The Coupe
Apr 12, 2017 01:22 AM
