Headlight washer cover question!
Old Oct 15, 2016 | 08:21 AM
Sylvain's Avatar
Default Headlight washer cover question!
Hi there,
I would like to know if the chrome metal washer headlight cover can fit as a replacement for 1996 XJS originally with plastic washer cover
Thank you
Sylvain
Old Oct 15, 2016 | 09:52 AM
ptjs1's Avatar
Sylvain,
I thought that the big-bumper XJS was only ever fitted with one type of wash cover, part numbers LHC7054AA & LHC7055AA.
Which are the different part numbers to which you're referring?
Paul
Old Oct 15, 2016 | 12:11 PM
Sylvain's Avatar
Hi Paul
This the part number DAC7927
It is for models prior to 1995
I was wondering if it can be fitted
Thank you
Sylvain
Old Oct 15, 2016 | 01:16 PM
ptjs1's Avatar
Sylvain,
DAC7927 & DAC7928 were fitted only up until April 1993 from when the big plastic bumpers were fitted. I guess it's possible they could be fitted with some cutting and fettling but would suspect they were changed because they don't fit exactly on the new bumpers.
As you probably know, only DAC7928 is available new.
Good luck
Paul
Old Oct 15, 2016 | 01:19 PM
Sylvain's Avatar
Thank you Paul
I ordered this part from UK, will let you know when I will have it installed
Best
Sylvain
Ipc838
Jan 12, 2018 01:20 PM
XJsc-guy
Oct 7, 2016 09:04 AM
DrScientist
Apr 11, 2014 05:51 PM
racer9816
Aug 23, 2013 10:39 PM
Drb007
Mar 19, 2013 03:57 PM
