Headlights flash and Horn chirps continuously after shutting car off???
Old Oct 11, 2020 | 09:32 PM
sd63141's Avatar
Default Headlights flash and Horn chirps continuously after shutting car off???
When I turn the vehicle off (1992 XJS convertible) the horn will chirp and the headlights will flash at the same time in intervals of about 3 seconds. The only why I can get it to stop is to disconnect the battery. I have tried to lock the doors manually as I believe the key FOB doesn't work. Anyone else experienced this?
Thanks,
Scott
Old Oct 11, 2020 | 10:08 PM
malc4d's Avatar
I would guess the alarm system need programing. When you reconnect the battery does it chirp ?
Old Oct 11, 2020 | 10:19 PM
sd63141's Avatar
malc4d, yes it does the same thing when reconnecting the battery as well... I’ll try and run down the alarm and let you know. I appreciate the info!
Old Oct 11, 2020 | 10:22 PM
malc4d's Avatar
you will need the keyfob to work. try pressing it after a chirp, if the tone changes then it is working. Press it after every chirp,(5), if it doesn't change the tone try a new battery in the fob
https://www.jaguarforums.com/forum/x...manual-107758/
Old Oct 11, 2020 | 10:25 PM
sd63141's Avatar
Ok great, I’ll give it a whirl tomorrow and let you know. Thanks again!
Old Oct 12, 2020 | 11:10 AM
sd63141's Avatar
Malc4d, it worked like a charm. Thanks for the help!!
Old Oct 13, 2020 | 07:20 AM
malc4d's Avatar
Here to help
philwarner
Nov 30, 2020 10:55 AM
Axxel
Sep 28, 2020 07:33 AM
carlorner
Mar 30, 2015 04:49 PM
2000CAXK8
Mar 15, 2012 11:46 AM
MDJag
Jan 3, 2010 04:14 PM
