heat from demister vents, set on cold
Old Feb 20, 2016 | 07:58 PM
Doug's Avatar
Originally Posted by Hoppy
Thanks Doug I've on the computer for hours, looking in all the wrong spots obviously! I reckon I found it just as you were typing your post!
I pointed you to the same spot about two weeks ago. Look at post #2 in this thread
anyway it's printing now and i'll be doing some testing this afternoon
Good luck. I think it has something like 47 different tests. Hopefully you'll hit paydirt!
Old Feb 20, 2016 | 10:36 PM
baxtor's Avatar
Thanks Doug I've on the computer for hours, looking in all the wrong spots obviously! I reckon I found it just as you were typing your post! anyway it's printing now and i'll be doing some testing this afternoon
A couple of points l would make are that the tests should be used as a guide. I have found some of the readings can be off by a small margin and yet still have a perfectly operating system and some are just downright confusing, for instance #56 & 57 call for same settings yet required results are totally different.
Lastly the warning about shorting pins should be taken VERY SERIOUSLY.
Old Feb 24, 2016 | 01:57 PM
Hoppy's Avatar
Looks like my ECU is busted, I wonder can I wire the centre vent solenoid to the Demister solenoid? if theyre both off - ie demist is selected on the RH control I will get demist air, and if they're both on (low - High) I'll get centre vent air....?
Old Feb 24, 2016 | 03:50 PM
baxtor's Avatar
You also have the blend flaps to contend with and you can't control them manually.
I just last week had to replace my ecu too, found one on ebay in UK for 30 pound and 12 pound postage was here 5 days later in the car and all good. Same guy had another on there for same price.
Greg in France
Jan 30, 2016 04:19 AM
xjsman89
Jan 29, 2016 10:05 AM
bsogorka
Feb 13, 2012 01:04 PM
bruca003
Apr 18, 2011 09:41 PM
