Heated seat always on
Old Jun 22, 2020 | 12:09 AM
wrightbenz's Avatar
Default Heated seat always on
Little issue the passenger seat appears to be on all the time. The light is on in the switch and it I press the switch I hear the relay click but it latches again.
guessint I have a shirt to ground somewhere. Oh and by the way the seat isn’t getting warm so I imagine the seat heater doesn’t actually work.
I don’t want to leave a shot to ground though.
anyone no where the seat relay is and where the wiring runs ?
Old Jun 22, 2020 | 12:19 AM
VancouverXJ6's Avatar
Its easy to follow if you feel where they go, just for starters I'd pull the fuse now to avoid unexpected fires. My truck had a similar issue but the heater was working to the point of heating the wires to skin burning temperature.
What year is your car that will help us answer questions.
Old Jun 22, 2020 | 12:37 AM
Doug's Avatar
Not sure what model you have but on my '88 the relay was on the LH component panel and had a slew of brown/yellow wires. The relay provided voltage for the heaters and the lumbar pumps. From there the power went to four separate fuses which should be labeled
Old Jun 25, 2020 | 12:07 AM
wrightbenz's Avatar
my car is an 89
djsomebody
Jan 25, 2023 04:38 PM
jagger
Nov 4, 2020 05:57 AM
01XJVP
Jan 22, 2019 05:45 PM
Barry_Tucker
Nov 14, 2017 06:20 PM
62sunbeam
May 5, 2014 12:55 PM
