Heater water valve. 1996 4.0
Old May 12, 2015 | 05:14 PM
RagJag's Avatar
Default Heater water valve. 1996 4.0
I have been having AC problems in that the air is very cold when I first start the car and leave home. After stopping at a store and then starting the car the AC is not nearly as cold. The difference in dash temperature is 43 degrees and then about 55 degrees.
Investigating the problem, I found that the water valve was not cutting the water off from entering the heater. Removing the valve I discovered the valve was broken inside. The vacuum pot was pulling the valve to the open position and looked okay but was leaving the valve open.
My reason for posting this is to possibly give any of you with a similar problem with your AC something to consider.
Luck, RagJag
02jagstype
23
Oct 23, 2022 07:03 PM
Ozzy_UK
45
Feb 19, 2019 02:05 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
Saturbo
Sep 8, 2015 07:35 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
