Hello
Old Jun 4, 2020 | 05:32 PM
Woodie's Avatar
Thanks Metal 144
Yes being a manual makes it more involving rather than just putting it into "D"
They actually made a few early manual V12's they are incredibly rare!
It would be interesting to know how many 6 cylinder manuals were produced!
I may contact and ask The Jaguar Heritage at Gaydon.
Ivan
Old Jun 12, 2020 | 10:51 AM
Woodie's Avatar
Hi Lee
Just to update you the accumulator was replaced today no dramas straight forward no brake fluid spillage or pressure issues.
The pump now kicks in after eight brake pedal depressions. It now recharges with the pump turning off after approximately eight seconds. This compares previously with two -three brakes pedal depressions and at least 40 seconds to recharge it until the pump turned off.
Also passed the MOT
Ivan
Old Jun 12, 2020 | 04:28 PM
leep123's Avatar
Originally Posted by Woodie
Hi Lee
Also passed the MOT
Ivan
Well done Ivan.
What a great day you have had. Accumulator sorted and MoT pass plus it looks like some dry weather this weekend to enjoy a good drive!
Where did you obtain the accumulator? I think I will replace mine also.
Cheers,
LeeP
Old Jun 12, 2020 | 05:23 PM
Woodie's Avatar
Thanks Lee
I purchased the accumulator from Island 4x4 they are based in Kent the cost was £90.00 +VAT with free and quick delivery just looked they are still at that price.
The accumulator is originally for a P38 Range Rover and is manufactured by Wabco P/N STC2784.
The stated manufactured date on my unit was Feb 2019.
Ivan
Old Jun 19, 2020 | 05:25 AM
leep123's Avatar
Hi Ivan,
Reading my workshop manual it sounds as though this is just a simple process of unscrewing the old accumulator (after depressurising via brake pedal operation) and screwing on the new one. Is that correct i.e., no requirement to bleed the brakes afterwards?
Cheers,
LeeP
Old Jun 19, 2020 | 08:04 AM
Woodie's Avatar
Hi Lee
Yes that is correct, but as a precaution I removed the 2 fuses
One for the ABS and the other for the pump motor they are situated in the fuse box on the passenger side below the glove box.
Even though the car had been standing for a couple of weeks without it having been started or the pump operated I still pumped the pedal at least 15 times just to be sure there was no pressure in the system.
The original accumulator was tight and a length of pipe was need for extra leverage, I wedged a small piece of wood between the pump motor and the fixing bracket to reduce the twist and strain on the pump mountings.
The new accumulator just screwed in and there was no brake bleeding required.
I removed the car from the garage and washed it the other day and left it standing for an hour or so when went to put it back later, the pump motor did not even start up so the pressure was retained by the system, this would not have been the case with the old accumulator.
Have you ordered your new accumulator?
Good luck.
Ivan
Old Jun 19, 2020 | 01:08 PM
leep123's Avatar
Hi Ivan,
No, not purchased yet - been busy on other (non-Jag) projects but thanks for the additional pointers on how to do. One query I have is that, according to my manual, the accumulator is initially charged with nitrogen at 84 bar. Don't know how critical this pressure is but does the unit you fitted state what the initial pressure charge is?
Thanks again,
LeeP
Old Jun 19, 2020 | 03:54 PM
  #28
Woodie's Avatar
Hi Lee
I checked the spec in the P38 Land Rover Workshop Manual, I also contacted Wabco and they both state a precharge of 80 bar when new.
Even so I would guess the 84 bar of the original Jag one on yours and the one removed from my car will be considerably less than that now due to age.
Do you plan on attending the 45th anniversary at Gaydon on the 5th September if it still goes ahead?
Ivan
Old Jun 20, 2020 | 11:38 AM
leep123's Avatar
Hi Ivan,
Thanks for passing on the additional information. I have just ordered - price still the same.
I have Gaydon in my diary but also have an MG event on the Sunday. Hopefully I can do both and we can meet up on the Saturday and compare cars.
Cheers,
LeeP
Old Jun 21, 2020 | 05:34 PM
  #30
Woodie's Avatar
Hi Lee
That would be great let's hope it can still go ahead and and we can meet up with the cars and have a chat.
Good luck with the accumulator repair.
Ivan
Old Aug 16, 2020 | 04:27 PM
  #31
Woodie's Avatar
Hi Lee
I have not been on here recently. Hope you are well.
Did you manage to replace the accumulator? Do you still plan on going to Gaydon on the 5th September?
Ivan
Old Aug 17, 2020 | 11:29 AM
  #32
leep123's Avatar
Hi Ivan,
I have bought a ticket and would like to attend but have a lot of family stuff going on around that time plus there are a couple of jobs I would like to attend to on the Jag before a journey to Gaydon. So, I am not 100% sure at the moment. If you ping me a PM with your email / phone I will do the same so we can confirm nearer the time.
I haven't got round to changing the accumulator yet. Mine came with a nut closing off the end. I presume I remove this nut to expose the thread and just screw the new one in? Did you use a strap wrench around the old unit to remove it or the allen key slot moulded into the top?
Cheers,
LeeP
bigpigpants
Jun 21, 2023 05:16 PM
AllanG
Jan 9, 2021 04:16 PM
barryf4343
US Northeast
May 8, 2018 12:53 PM
Terry007
Jul 13, 2016 06:05 PM
denverjagowner
Mar 28, 2014 10:03 AM
