Exhaust helicoil nut
Old Aug 17, 2020 | 05:14 PM
Pirk's Avatar
Default Exhaust helicoil nut
Of course, went to count and got to 7 and oh crap where's the eighth one My guess is either one of my 4 kids grabbed the thing or it's somewhere in the mystery garage blackhole...
Now, to find a replacement (or probably 8 replacements as I was going to de-rust and polish or paint, so now just assume get 8 brand new ones that are already nice and shiny). Ok, so after research, looks like these were single use anyway, so probably explains why they were loose and all eight should be replaced..
Does it have to be the helicoil type or can some other replacement suffice? And what are the recommendations as (now that I've actually researched a bit) a big problem is with the manifold nuts loosening due to the heat cycles (total sense)?
Thanks in advance
Old Aug 17, 2020 | 06:22 PM
Dleit53's Avatar
I would use the helicoil style nuts if available, they are less prone to seizing. I have used a standard nut when a full set of original nuts was not readily available.
jithu9684
May 20, 2020 10:45 AM
Finn
Jan 6, 2018 02:35 PM
malc4d
Apr 15, 2015 02:06 PM
stasha
Mark V - X 420G
Sep 8, 2013 02:30 PM
