Help with problem with AC switch.
Old Jul 5, 2011 | 04:41 PM
Geordie68's Avatar
Default Help with problem with AC switch.
If I turn the AC on to low or medium speed the blower kicks in for 1/2 a second then stops. If I turn it to high it works fine right away, and once I've had it on high I can go back to medium or low and it works fine.
any ideas? This is on a '92 XJS.
Old Jul 6, 2011 | 02:21 PM
xjrguy's Avatar
I've run into that a few time over the years. Even saw it a time or two on the later years of the XJ40. I think the only truly permanent solution is to replace the A/C control module. That is an expensive proposition, though. Several folks have just elected to put up with it.
Cheers,
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
