Higher rear end than front end?
Old Apr 28, 2011 | 08:23 PM
JameyXJ6's Avatar
That sounds like suspension sag to me, which means the front springs are worn out. But that's only a guess.
Old Apr 28, 2011 | 10:13 PM
Doug's Avatar
Yes, front spring sag is fairly common.
Also common is to replace the rear springs and ending up too high !
Old May 20, 2011 | 06:21 PM
cadfael_tex's Avatar
Think I'm looking at the same car. Guess he didn't buy it, wonder if that should be a signal to me?
Old May 23, 2011 | 06:41 PM
Front end ride height actually looks about right in the on-line pictures. It is the rear end that looks to be riding substantially high. If it is the rear springs being improperly installed (which is what you were saying right?) how easy is it to set right?
Old May 23, 2011 | 07:28 PM
Doug's Avatar
No, I wan't trying to imply an installation problem.
Over the years I've heard/read from quite a few XJS/XJ6 owners who have had trouble getting the correct ride height with replacement springs....with "too high" being more common than "too low". Sometimes, not always, "too high" becomes "just right" after a few weeks of settling in.
My personal opinion, not confirmed by actual research, is that vendors are selling replacement springs that are not correct for the vehicle. Yes, they physically fit...but are not the correct length or strength. When I see a single part number with a description of "1980-1987 XJ6 and XJS 1975-1995", or similar, I suspect the spring is a semi-generic replacement and not "tuned", if you will, for each specific application.
Old May 23, 2011 | 10:23 PM
So the fix is getting the actual specific spring? How much do they run? IIRC (which is always suspect) spring replacement can be a DIY if you have a method of compressing the spring to install it - no?
Thanks for your answers.
Old May 24, 2011 | 06:08 PM
nosox's Avatar
This is true, happened to me. The springs were the correct length and properly installed but ride height out of the shop was almost 2 inches high. After a couple of weeks they settled, but still a proud inch high. A big tool box and a sand bag in the trunk got it right, leading me to wonder if maybe we are being sold springs for convertible, maybe thats all thats available these days. Just my 2c
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
Dz1rfj
Jul 17, 2018 10:29 AM
KarimPA
Sep 12, 2015 08:15 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
