Hood Control Module
Old Jun 27, 2022 | 03:28 PM
GLM's Avatar
GLM
Default Hood Control Module
I recently acquired a 1996 XJS Convertible. The top & rear quarters weren't working, windows were down.. I found a blown 5A fuse behind the right rear tail light compartment that provides power to the top and window relays. Replaced the fuse, top and left rear window came up, the right rear window didn't. I ran a 12v feed to the motor from a wiring plug in connector in the trunk that runs from the window relays to the window motors. This proved the wiring to the window motor and the motor itself are OK. It look to me that the Hood Control Module interfaces with the top and windows and I'm thinking this is where the problem is. I've read numerous solutions on this site but I haven't come across anyone who replaced the Hood Control Module to try and make the windows work. I'd appreciate hearing from someone who replaced the Hood Control Module and corrected the problem. Thanks
Old Jun 27, 2022 | 03:42 PM
ptjs1's Avatar
GLM,
I've never heard of a failed hood ecu causing window problems before.
Have you tried swapping the relay from the other side to try and eliminate if the relay is at fault?
Paul
Old Jun 27, 2022 | 03:55 PM
GLM's Avatar
GLM
Hey Paul, thanks for getting back to me. I tried swapping relays first then replaced all of them. All indications are that the right rear relays aren't getting any input from somewhere and the only thing I can see on a wiring diagram that is associated with the top and windows is the Hood Control Module. I was hoping maybe someone has come across this. GLM
4catstudio
Apr 28, 2024 10:25 PM
Zolomoro
Dec 14, 2019 02:07 PM
carsnplanes
Jul 23, 2018 01:33 PM
AC0FC
Jun 24, 2018 09:57 PM
ahwy111
Nov 26, 2015 10:44 AM
