Hoses
Old May 9, 2018 | 09:51 AM
brinny's Avatar
Default Hoses
Any advice on replacing the hoses please lads. Is it best to buy silicon and would you buy a kit or individually? Thanks.
Old May 9, 2018 | 10:38 AM
Greg in France's Avatar
Brinny
Honestly a Manners kit for about 70 quid is in my view quite OK. If you go to silicone, then silicone classic hoses, somewhere in Leics, are the only ones I would trust, but double the price; AND you need Mikelor clips with them, AND you need to tighten them up after a few hours of running after first fitting them - which is not at all easy on many of them.
The best thing to do, IMO, is to buy a kit,; but also buy a length of top notch Viper silicone hose of the right diameters to cut to length to do the three crosspipe hoses with. These get a huge amount of heat and silicone for them is worth it I have found, as when renewing them, the normal ones always look on their last legs.
The normal kit elsewhere will outlast you unless you are putting 25,000 miles a year on the car.
Old May 9, 2018 | 12:51 PM
Vee's Avatar
Vee
I'm not sure I've gotten comfortable with the sudden and spontaneous ruptures silicone hoses provide, and for quite a premium.
The standard type hoses seem to last a mighty long time and are more apt to give warning signs before imminent rupture.
That being said, if there are specific hoses on a v12 that would benefit from silicone, then have at it!
What about something completely asinine, like sleeving a silicone hose...nah, nevermind, I feel foolish as I even type it.
Old May 9, 2018 | 02:29 PM
Daim's Avatar
Just make sure the silicone is reinforced with textile... As soon as silicone gets a certain pressure, it will expandiert and burst. Have had it happen on a different car before.
Old May 9, 2018 | 03:46 PM
Edelweiss's Avatar
Everything I learned about replacing hoses, belts, radiators, and thermostats, with an extra bonus question on the hood shocks:
https://www.jaguarforums.com/forum/x...rtible-162009/
Old May 10, 2018 | 09:22 AM
brinny's Avatar
Thanks for the advice all. Manners hose set it will be Greg. Edelweiss, thanks for that link. That is the type of thing I need , tips like fit to rad before engine . I have the engine out of the car at the moment as it happens. Once again much obliged to all contributors.
Old May 10, 2018 | 09:48 AM
Do the crosspipe and all the non-engine heater connections you can before dropping the engine back in.
Old May 10, 2018 | 09:50 AM
sidescrollin's Avatar
I bought a kit about 6-7 years ago and it is still nice and supple. If you know you are tossing old hoses, save yourself some aggravation and just cut in line with them using a razor blade to make removal easy, this may even be necessary are difficult hoses, like the heater hoses.
damienedwards
Sep 13, 2009 01:30 PM
daddyo007
Jul 30, 2009 05:20 PM
Gus
May 29, 2009 09:28 PM
sugarcean007
Dec 15, 2008 06:49 PM
Brake buster
Apr 12, 2008 07:34 AM
